Feb 2016
Thanks for the detailed description on how to apply PVA. I will try that. And probably get a glass plate to replace the blue plate that came with the FFCP.
The platform is well leveled. So, I suspect that won’t improve my prints.
Hi Dhin, thanks a lot for the very detailed recommendations. I wil try that and change to glass plate.
I checked the measurements of the blue baseplate on the FFCP: 232x154mm. The glass plate on the UM2 is 4mm thick. The makersome upgrade in your video is 5mm. This video, also from makersome, explains in more detail how to install a glass plate and how to reset the z to the higher baseplate. I’ll get cracking on this. Thanks.
My printer came with http://www.buildtak.com/ 3 and I have been very happy with the results so far. I still use rubbing alcohol after every print to remove and finger grease left behind when removing. Others results may vary but I find for some prints it sticks too well and I have to really work to get it off. I am printing without a heated bed and using PLA. Largest single layer was something like 4"x1.5" rectangle without any issues. Still on my first of 2 sheets of the stuff (200+ hrs).
I have test for evey kind of method, including blue tape, PVA glue, hair spary, heated bed, glass bed…all without full satisfaction. But after I start to test and use the “Magic PLA solution” Ifrom www.3d-bottech.com 4 that enable me to have a just right stick during print and release in a second without problem like PVA glue that have too much stickness and will make your print very hard to remove after print, one time, PVA glue stick so hard that rip chips off my glass bed. SO, I no longer use PVA glue stick any more. After I test and use “Magic PLA solution” It work perfect every time for me on glass bed at only 50 deg C. Very happy with this solution since it also enable to create mirror like smooth bottom of the print. Highly recommend for anyone have issue of not stick issue for PLA.
Another vote here for: heated bed (60 degree), glass, pva glue (specifically I use “pritt stick all purpose liquid white crafting glue”).
Also check temperatures, and cooling - a fan could cause warpage. The plastic needs to come out hot, then be cooled - ie fans should not be pointing at the nozzle or cooling it in any way. You can usually control fan speed with a gcode command, so you can turn it down if its too extreme. I use a 40mm layer fan.
Mostly i find that glue and low temperatures stop the warping.
Let’s make this easy for everyone - this works for me every single time!
Glass bed, 115 - ABS, 60 - PLA, 50 - Nylon and t-glase, and some glue stick! … and a perfectly leveled bed. I haven’t had to use anything else… EVER!!!
For glue stick, I had some scotch brand that applies purple but goes clear when dry. Worked like a charm and able to run several prints before having to re-apply. Plus, a wet cloth to the bed and it makes it all new and smooth again. I seriously just load my SD card and start printing, no worrying about if it will stick or warp.
I also use UHU brand, but it sticks a bit too much in some cases, making large surface area prints difficult to remove without soaking in water to dissolve the glue.
Remember kids, 95% of your adhesion problems are bed leveling issues and first layer height. Spend the most time on this and you will reap the rewards! Don’t assume one leveling pass and you’re good to go. Take your time and keep doing it until it is perfect. Try printing this Print Bed Level Check by laird - Thingiverse 12 after leveling and and check the shape of the layer is consistent (and well squished in).
Hope my rant helps someone!
I have a Ultimaker 2 and a ultimaker 2 extended. On both printers i used a simple hairspray (Gardner Fructis Mega Strong with bamboo extract). I spray it directly on the glass plate with 55°C. This work for PLA and ABS. I never have wraps with this.
the ultimaker glass plate has a coating that is hydrophobic on at least one side…
This also helps it stick to PLA.
The glass plate also has to be relatively clean, use alcohol based cleaners!
Blue painters tape works reasonably fine on my old umo
14 days later
Use 3DLAC. Literally the best thing for platform adhesion, bar none, you will never look back. This spray makes your prints stick so good that you will literally pull off pieces of the glass bed if you try to take it off right away. But 10 minutes in the fridge and it comes off easily. Warping just isn’t an issue for me anymore.
Another possibility for a build surface coating is 3D-EEZ, not tried it myself yet.
Hi @jasu, as requested I have some information about my experience with 3D-EEZ that I have been trying out for the past two weeks. I have been printing with PLA and with ABS. For PLA it is excellent - the parts stick firmly to the build plate and then when cooled down the parts will pop off. For ABS it is good - the parts don’t stick as hard as PLA, but still it is sufficient. There is still the possibility of some warping with large parts but it certainly behaves better than just ABS juice.
I have noticed that it is VERY IMPORTANT to be liberal with the coating and ensure the layers are dry before use. Also Z-axis adjustment must be very carefully done. If the z-axis adjustment is too small, the nozzle is too close to the bed and the 3D-EEZ gets squished and heated too much to the bed - then the part will get stuck very very hard to the bed and it is extremely difficult to remove it. But some playing around and experience helps that - now I find it very good and I would recommend it. I will be ordering another tub. Oh and another thing - it comes in two sizes, a bottle and a tub - don’t bother with the bottle, if you’re going to get it then get the tub.
I am now going to test a product called “Buildtak” which is a film cover for the bed and is supposed to take PLA and ABS. I will advise again its effectiveness here in due course.
