Hi, does anyone on this hub print with ABS to a size of over 405mm?
Thank you
Gary
Hi Gary, not sure I understand, do you mean you need a 40 cm print?
I have printed something of that size before by: Splitting it up, printing the parts, welding the parts together with a 3D pen, Sanding weld seams down and then surface finishing with acetone and lacquer.
Hi, yes 40cm x 3cm
