HughN
I almost started grieving when my Anet A8 stopped working, I missed it so much!
The extruder doesn’t seem to be able to push the filament through (please see this video
https://photos.app.goo.gl/QvXKcpfY2yCZTHPc9) the cog just ‘bounces’ to and fro very slightly.
So far, have:
- Turned up the extruder tension. No change
- Swapped the motor wire for the Y-axis and moved the Y-axis. No change.
- Swapped with a new motor. No change
- Swapped motherboard. No change
- Tried a new nozzle. No change
- Tried a new hot-end. No change.
- Tried a different extruder (the gold-anodised one in the video)
- Changed to a 20 point stainless-steel cog. No change.
- Increased the temperature to 210° C. No change.
- Checked the temperature with an IR thermometer. Spot-on
- Tried filament I have used before with success. No change.
- Tried brand-new filament. No change.
I can push the filament through easily enough but the extruder doesn’t seem to have the oomph to do it - it eventually starts to strip the filament.
Any ideas would be gratefully received.
Thank you,
Hugh
