May 2017
I am assembling the A6 and have a problem at attaching the small acrylic part to the fan/nozzle housing with the specified M3 * 10 screws. The screws are tight before the small part is secure.
So the screws are too long or the holes not deep enough!
Also the M3 * 10 screws have countersunk heads but the holes on the small acrylic part are not countersunk!
Has anyone met this and found a solution?
Thanks
Nigel
Have another look through, you’ve probably put the wrong ones in somewhere. :’) or you might need a spacer or something from one?
