Thanks @DeKam, it is about 300mm (12 inches) long by 170mm high (7 inches). The trickiest bit is the spring which I printed with 20% infill, apart from that i should be good. Let me know how you go if you print it, I would love to see how others get on with it.
The only real tricky part with the printing is the spring, I print it horizontal with 20% infill and it usually comes out nice, then you have to carefully remove the supports.
Hey, I’ve downloaded this print and tried to print it using PLA, which is a corn based plastic but 10 minutes into the print, the extruder starts going wack and screwing up the print. I assume this is probably a problem with my printer, but could it also be the fact that i’m not using ABS? Let me know.
Sounds like a problem with the printer, the only difference between printing this design in PLA or ABS is the tolerances of the linkages and moving parts. Have you done any other prints in PLA? And did they print fine?
I was able to get the print working, it ended up just being a problem with the filament I was using. I first tried a sparkly black but it didn’t work, so I switched over to straight black, and it is printing fine.
Ah that’s good (about the design now working not the dodgy filament haha). Let me know when it’s done, I’d love to see pictures of another completed bike!
