Hello, We need to Scan few objects in High Resolution and Print in what is turn around time. Thanks.
within 24hours, and if you are here in Toronto we can deliver too.
What is the output file?
Is it a raw scan, or are the textures “fixed” prior to sending it to the client?
What tolerances can you hold?
we usually output in .stl format but if you need it in any other format we can accommodate that too, and what do you mean by tolerance?. We can edit the mesh according to your specification.
Hello, i need to 3d print CT Scan, what is the process and if you guys are open this weekend?.
Yes we can convert your ct scan (dicom file) to .stl and our Hub is open 7 Days a week, please check our website www.qrinting.com for more detail on operational hours.
The parts that I would have scanned are really high-tech reamers with intricate faces and are designed to a high tolerance (+/-.0005"). The whole idea is having the ability to scan them for cross-referencing and editing for rapid prototyping (without needing to redesign it in a different CAD software).
Yes we can help you with this.
I am looking to get a scan done of the shell of an xbox one controller and a PS4 controller exported in .stl format. Would you need the pieces or could you acquire them for the scan?
Yes we require the pieces for scan.
