can we use isense 3d scanner for ipad to scan a structure ? like how structure sensor works
created
Dec '16last reply
Dec '16- 6
like
Sure. It will be a matter of accuracy and detail that will be collected with that device. If you are looking for an general oveall data cloud for a structure it will be able to created.
yes you can
Hi Anu,
it depends on the structure. The solution of the iSense is quiet bad, approx. 1.5mm, so You can just scan large objects. For smaller parts, the Artec solutions are more suitable.
cheers Andreas
I have a Sense 3D v2 scanner from the same developer (Sense 3D and iSense are quite similar) and it works like a kinect for Xbox.
It can scan pretty accurate but you definitely need some practice and also make your self familiar with this technology.
You should test the best results.,
Autodesk remake does it with pictures (up to 250 images in the free version!)
In fact the Occipital structure sensor is the same hardware as the iSense is, but the iSense isn’t supported anymore by Occipital.
