Nov 2016
Hi Eno,
It’s tricky to get good skin tones with an Eva, but not impossible - it took us a quite a while to get it right. I’d be happy to take a look at the file and hopefully can point out what needs doing differently.
Tim
How can i have good even lighting ?
And how to tell when it’s/it’s not enough light ?
Having a great design staff id imperative. Happy to help if you need it. The eva makes great scans but they do need work.
Usually the problem with the skin is that it gets printed somewhat darker than the actual.
What we do is manually edit the texture and make it brighter using zbrush. Then export it as wrl and open it in the old (and better) Zprint!
Is that the problem you’re having?
If you use ZBrush, switch to the Flat Color material and any shadows on the model will be very obvious.
The printer will not output exactly what you see in zbrush.
You would have to do come color testing with zbrush and your printer to get similar skin tone.
www.cokreeate.com 1
Hi @eno1509 I’m having the same problem. Can you share with us if you’ve solved the problem?
6 months later
If any one is interested in testing some binders I would recommend www.3dcolors.pl :slight_smile:
