Awesome community!
I need your help. I’ve been playing with an idea for a while and this weekend I want to get it started
The goal is to 3D print a World Map, about 2m wide. The idea is to have actual elevation represented and print it like a puzzle, with each piece being a country / state. It will take me about 250 printed pieces I expect which on average should fit my printers.
My question:
Does anybody know, can help me, with translating a world map into different .stl files per country/state, with the actual elevations represented in the files? Has this already been done before maybe?
I’ve seen similar concepts like this one: World Map by toddsplod67 - Thingiverse, but I’m aiming to have this per country and on a larger scale.
Help is much appreciated.
Cheers!
Filemon
I would be interested in helping you out. Looks like a great idea.
You can use this to generate STL files from Googlemaps Terrain2STL
Let me know if you need help printing
This is a nice tool! I actually wanted to print my own country like that, however this tool doesn’t really allow to generate it as bis as a country (even a really small one). You can do cities for sure tho!
Thanks, any idea for the first step? Creating the files?
Ermahgerd!! Threrder prernerd glerb?! Ertsertnerng!! Gerferert, Flermern!!
For the Netherlands this would be tricky , since most of u live below NAP!
Cinter
10
@meatcurry this is awesome, I’m guessing they are using the Google Elevation API. I guess my question is, do you know how to convert data from an API into a .stl? Apologies if this is a stupid question but I’ve done a lot of googling and this could provide cool data sources for physical IOT products, something that 3D printing offers perfect capability for!
Hi I’ve used http://jthatch.com/terrain2stl/ as well, and got some great results see
the only problem with this program is the size of the area you can convert, otherwise it’s great
