Nov 2016
16 days later
20 days later
4 months later
Ive been emailing them for months and still don’t have a resolution to my problem. They have replaced various parts but nothing has corrected the fault. Mine prints the initial layer ok but every layer on top of that is offset to the left. All I end up with is a mess of plastic with nothing formed.
Antony
6 months later
Has anyone ever managed to get this thing working? After over a year of trying just about everything I can think of it still refuses to do its job. Every time I attempt to print from it the print moves to the left. So instead of the item being built one layer on top of each other - each succeeding layer is slightly to the left.
Ive had replacement parts - updated software - checked every connection and every motor/band - nothing has helped. As far as I’m concerned its just a very expensive pile of junk.
I also started with the print bed not heating up. All I had to do was re-apply the firmware and then it started heating up correctly. I also removed the extra cooling fan and it’s cover as it was stopping the print head from heating up enough.
