3D printing service South Africa
Our 3D printing capabilities
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in South Africa
SLS 3D Printing service in South Africa
MJF 3D Printing service in South Africa
SLA 3D Printing service in South Africa
Over 302 customers are satisfied with our 3D printing service.
“Very fast turnaround. Great print quality.”
Tyler, Roodepoort
Standard ABS, FDM
“Very efficient in both responding to orders and printing.”
Marcello, Johannesburg
Standard PLA, FDM
“Absolutely perfect, came out just right. ”
Julian, Johannesburg
Standard ABS, FDM
“Excellent service! And quick turn around time!”
Shayne, Johannesburg
Standard PLA, FDM
“Great service, timely responses, good quality prints and amenable to additional request to make a project come together without hassle ”
Chris, Johannesburg
Standard PLA, FDM
“Awesome service as usual. Thank you Jason”
Hendo, Pretoria
Standard PLA, FDM
“Great servece, great print quality, awesome reaction time. Just all round a great experience.”
Adolph, Cape Town
Standard ABS, FDM
“Even with some of the lifting issues of my design, the print came out perfectly. Great to deal with and super communication.”
Raymond, Cape Town
Standard PETG, FDM
“Thank you for your prompt response and all-round great service!”
FJ, Cape Town
Standard PLA, FDM
“Quality is good, service and communication are good.”
DANIEL, DUBAI
Standard resin, SLA/DLP
“Amazing service and will continue using it.”
Mishal
Standard PLA, FDM
“Perfect print, great communication, fast delivery”
Ahmed, Abu Dhabi
Standard PLA, FDM
“Very good quality, happy to deal with them, i recommend them for any one who need 3d printing”
Islam, Doha
FDM
“I had a tight deadline and they supported me and delivered ahead of schedule. Happy with the result ”
Martin, Dubai
Standard PLA, FDM
“Amazing company. Fast work, friendly personnel, best prices, impressive quality. ”
Pavel, Dubai
Standard ABS, FDM
“Great service! Everything came out nicely. Thanks!”
Vojislav, Dubai
Standard PETG, FDM
“Great job, quick service, will use again. Very happy”
Cody, Dubai
Standard PLA, FDM
“Super professional. And good-looking too.”
ERAN, Tel Aviv
Standard PLA, FDM
“Great supplier, and the level of service makes me return and seek him out whenever I need something printed.”
Pasha, Petah-Tikva
Standard PLA, FDM
“Excellent service, very professional and helpful. Thanks a lot!”
Lior, Herzliya
Standard PLA, FDM
“Great service and transparency with regards to operations and product delivery with great quality print to boot. ”
Morne, Sharjah
Standard PLA, FDM
“The serivce was outstanding and I would recommend it!”
ABDULRAHMAN, Kuwait City
Standard PLA, FDM
“excellent work. they are very cooperative. i will use their services again.”
Yanir, Timrat
Standard Nylon, SLS
“lightning-fast and super friendly. 10/10, will print again.”
Andre, Kiryat Yam
Standard PLA, FDM
“Outstanding job! Will order again next time.”
Manjulal, Trivandrum
Standard ABS, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
