3D printing service Rhode Island
Our 3D printing capabilities
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in Rhode Island
SLS 3D Printing service in Rhode Island
MJF 3D Printing service in Rhode Island
SLA 3D Printing service in Rhode Island
Over 267 customers are satisfied with our 3D printing service.
“The print I received was perfect, and it arrived faster than expected!”
Brianna, Warwick
Standard PLA, FDM
“Jim was very helpful throughout my ordering process as well as promptly correcting a mistake made. I am extremely pleased with the service the network provides.”
Louis, Providence
Standard Nylon, SLS
“Great quality. Excellent customer service.”
Farzad, Cumberland
Standard PETG, FDM
“It was a pleasure working with this hub, and the part that arrived was beautiful!”
Ayah, newport
Aluminum, DMLS/SLM
“Great parts. They'll work just fine in my prototype.”
Paul, Mystic
Standard ABS, FDM
“Everything arrived and fit together as expected. They offered prompt response and updates about the status of my order and provided pictures when the print was finished. I'd certainly do business with them again.”
Christian, Shrewsbury
Standard PLA, FDM
“Excellent quality printing and cleaning, fast turnaround and delivery to USA.”
Leo, Northborough
Standard ASA, FDM
“No hassle or surprises, just the exact parts I needed. If not for a mistake I made in the shipping address, the parts would have arrived 2 days earlier than expected. ”
Alexander, Worcester
Transparent resin, Material Jetting
“I was very satisfied with all aspects of the professional service and quality parts that I received.”
barry, Gales Ferry
Standard TPU, FDM
“Great Customer service! Responded promptly and clearly! Completed printed parts extremely fast and shipped right away while keeping me updated along the way. Recommend 100%”
Matthew, Boston
Standard PLA, FDM
“Service was fantastic, upgrade advice was a very nice touch, great knowledge.”
Lee, Jamaica Plain
Carbon filled Nylon, FDM
“Great service, super fast, great quality. ”
Drew, Jamaica Plain
Standard PLA, FDM
“Beautiful print, received it in such a short period of time, I was actually shocked - looked fantastic in my model. ”
Taylor, Brookline
Standard PLA, FDM
“Parts are neatly printed and arrived on time. Awesome job!”
Paul, Brigton
Standard PLA, FDM
“Frew consistently delivers extremely high quality prints. I highly recommend his services”
Alex, WATERTOWN
Standard resin, SLA/DLP
“Very happy with the large print that came out. Hub offered to create custom changes to make sure no warping happened during printing. Parts came out very consistent and accurate. ”
Chong, Boston
Standard ABS, FDM
“Looks great! Thanks for the quick turnaround and clear communication, too!”
Jared, Concord
Standard ABS, FDM
“Extremely fast service - especially given the number of units - and no compromise in quality. Excellent communication as always.”
Paul, CAMBRIDGE
“Great! No problems and was exactly what I expected and ordered!”
John, North Weymouth
Standard PLA, FDM
“Top quality prints again. Can not complain at all. Fast, efficient shipping on great 3D prints. ”
Steven, Jefferson
Standard PLA, FDM
“Very impressed overall by the service and quality.”
Kevin, Boston
Standard TPU, SLS
“Thanks for the quick service and great quality!”
Andres, boston
Carbon-fiber reinforced Nylon, FDM
“Communication was excellent and parts came back as ordered”
Harrison, Somerville
Standard PETG, FDM
“Smart supplier, direct feedback, on the mark. ”
Paul, Acton
Standard TPU, FDM
“The prints were as I wanted. Great advice in choosing the materials. ”
Nish Mohith, Boston
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
