3D printing service North Carolina
Our 3D printing capabilities
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in North Carolina
SLS 3D Printing service in North Carolina
MJF 3D Printing service in North Carolina
SLA 3D Printing service in North Carolina
Over 236 customers are satisfied with our 3D printing service.
“Great hub, quick service and helpful information.”
Chris, Sanford
Standard ABS, FDM
“I greatly appreciate your promptness and quality of your print. This design is being used as a cell phone holder installed into the console of my Nissan 370Z, whereas otherwise, this car has no other practical place to hold a cell phone. The new install looks like an OEM feature of the console and adequately provides for the intended purpose. Thank you sincerely for your professional service.”
Chris, Greensboro
Standard ABS, FDM
“Good quality prints, would be willing to use again”
Bryan, Carborro
Standard TPU, FDM
“The parts look great - thanks for completing this for me!”
Gene, High Point
Standard ABS, FDM
“Order was completed early and as expected!”
Joshua, Holly Springs
Standard PLA, FDM
“Fast turnaround, and parts turned out great.”
Colin, Colfax
Durable resin (PP-like), SLA/DLP
“Product was great, expect specifications and worked perfectly for what they were needed for.”
Brent, Raleigh
Standard ABS, FDM
“Absolutely amazing and high quality 3D prints! I recommend to all! ”
Brian, raleigh
Standard resin, SLA/DLP
“Great service again. Parts received as expected.”
Ryan, Raleigh
Standard PLA, FDM
“Exactly the what I ordered and delivered quicker than expected. Knowledgeable. professional, and efficient!”
Harry, Roxboro
Standard PLA, FDM
“Part was made quickly and quality was excellent ”
Steve, Charlotte
Standard PLA, FDM
“Great print quality and customer service.”
Derek, Clayton
Standard PLA, FDM
“These parts are perfect! Highly Recommended”
John, Wendell
Standard ABS, FDM
“another great work from David - thank you”
Roger, Charlotte
Standard PLA, FDM
“Very happy with print quality and speed. We are interested in knowing max build size for future models. Thank you”
jason mizelle, zebulon
Standard ABS, FDM
“Looks Great !! Thanks for the timely response and high quality.”
Jimmy, Statesville
Standard ABS, FDM
“Super quick response time, very helpful and knowledgable. Received my parts very quickly and exactly as ordered, no complaints at all!”
Jason, Pineville
Standard ABS, FDM
“Great part, price, and communication was superb! Our company's go to for polyjet prints.”
CJ, Charlotte
Standard resin, Material Jetting
“Very happy with the print quality and service. ”
Jason, Effingham
Standard ABS, FDM
“Good communication, quick service, good print. Thanks!”
Charles, Columbia
Standard ABS, FDM
“Excellent service, fast communication, and very helpful through every part of the process. Strives for 100% customer satisfaction”
David, Wilmington
Heat resistant resin, SLA/DLP
“Super great job! and I'm so sorry about being late confirming the order delivered. I've been super busy. ”
Mario, Lexington
Standard PLA, FDM
“Very courteous and printed two of the provided objects. ”
Daniel, Jacksonville
Standard PLA, FDM
“The parts look great, and arrived faster than expected. I also really appreciated the test print and consulting he did for me on these parts.”
Andy, Lexington
Standard ABS, FDM
“Quick turn-around for a prototype! Very affordable! Will use again!”
Robert, N. Charleston
Standard PLA, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
