3D printing service New York
Our 3D printing techniques
With 90+ 3D printing shops in Protolabs Network (formerly Hubs), we produce high‑quality parts at competitive prices, from rapid Fused Deposition Modeling (FDM) prototypes to functional end parts made with Selective Laser Sintering (SLS) and Multi Jet Fusion (MJF).
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in New York
SLS 3D Printing service in New York
MJF 3D Printing service in New York
SLA 3D Printing service in New York
Our quote builder interface for instant 3D printing service online
Over 247 customers are satisfied with our 3D printing service.
“Great prints, great communication. Will use this seller again.”
Chad, Bushkill
Standard ABS, FDM
“looks like the photos, was a tough print and will serve its purpose well”
Paul, Freehold
Standard PETG, FDM
“Just as expected. Fast delivery. No issues.”
frank, clarks summit
Standard PLA, FDM
“Awesome service and great products. Couldnt ask for more.”
Danny, West Point
Standard resin, SLA/DLP
“Great job and shipped quickly. Item was received before quoted delivery date. ”
Mark, Flanders
Standard PLA, FDM
“Service was quick, friendly and well done. will use in the future. ”
Joel, New City
Standard PLA, FDM
“Quick and courteous,with high qualify results, I would definitely work with them again”
Alec, Ridgewood
Standard ABS, FDM
“Very prompt communication, excellent print finish, met all my expectations.”
Vikas, woodclliff lake
Standard PETG, FDM
“The best 3D printing service in the world !”
John Paul, Croton-on-Hudson
Standard ABS, FDM
“Always PERFECT Prints. I measure with calipers. Oh, and fast shipping. What more could you want? Best printer around!”
Michael, Croton-on-Hudson
FDM
“Print as expected. Communication and flexibility was excellent.”
Nelson, Florham Park
Standard PLA, FDM
“Well packaged, on time, and got frequent updates.”
James, Paramus
Standard ABS, FDM
“Outstanding quality and quick delivery, would order again any time. ”
Ed, Elmwood Park
Standard PLA, FDM
“Great service. Communications and speed were exceptional.”
Richard, West Orange
Standard ASA, FDM
“Arrived quickly with updates throughout the process, exactly as requested.”
Rob, Endwell
Standard TPU, FDM
“My order was printed and shipped quickly. Excellent service and communication.”
Martin, Wallington
Standard ASA, FDM
“I ordered a print at the cheapest level and the quality is much better than I anticipated. These guys examined my drawings in no time, got the print started, snapped images post-print, and got it out the door in the same day. A+ service.”
Valentino, Easton
Standard ABS, FDM
“Great part, works and fits exactly as i needed”
Justice, Utica
“Excellent service. Great person. Very helpful. Quality work!!!”
Yinka, Irvington
Standard PLA, FDM
“Perfect. Prints were started the day of upload and delivered before the deadline. Quality is near perfect! ”
Bryan, Kearny
Standard ABS, FDM
“Great communication and custom part fit perfectly. Thanks! ”
Michael, Union City
Standard PLA, FDM
“Always a wonderful experience and perfect print. Thank you!”
Sue, BETHLEHEM
“Fast turnaround, quality print, good price.”
Brian, New York
“Very quick and professional. Will buy from again. ”
Chris, New York
“Great communication and printed parts looked great. Highly recommend!”
Mark, New York
Standard ABS, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
