3D printing service New Mexico
Our 3D printing capabilities
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in New Mexico
SLS 3D Printing service in New Mexico
MJF 3D Printing service in New Mexico
SLA 3D Printing service in New Mexico
Over 198 customers are satisfied with our 3D printing service.
“Parts look great and got them in time on a rush job - thanks!”
Benjamin, ALBUQUERQUE
Standard PLA, FDM
“Great communication, speed, and the part looks terrific.”
Dale, Albuquerque
Standard ABS, FDM
“I received my order earlier than expected. I am very happy with your service and will definitely use you guys in the future.”
Russ, Hobbs
Standard ABS, FDM
“Fantastic parts, delivered quickly. Thanks!”
Andrew, Crested Butte
Tough resin (ABS-like), SLA/DLP
“It is this simple. Wouldn't work with anybody else. Very responsive and helpful. Always willing to provided insightful input.”
Joshua, Colorado Springs
Standard ABS, FDM
“Printed parts came out awesome (again)! Also arrived in my hands 3 days before the deadline to ship out even occurred. Fast professional quality prints, recommended again!”
Nicholas, Colorado Springs
Standard Nylon, SLS
“Quick response time and great customer service!”
Karla, Midland
Standard PLA, FDM
“Great experience, I got exactly what I was looking for in a very short amount of time. ”
Gregory, Avon
Standard PLA, FDM
“Parts look great... and they are a perfect fit! Thanks Brandon!”
Joseph, Littleton
Standard ABS, FDM
“Very quick turnaround and exactly what I needed. Thanks!”
Zach, Evergreen
Standard PLA, FDM
“Good parts and service. Will order from again. ”
James, Tucson
Standard ABS, FDM
“Very responsive and professional. Part was exactly what I ordered and done on a very tight timeline. I will use this service again.”
William, Grand Junction
Standard Nylon, SLS
“Quick and easy. Sent my parts and told him how I needed them, and he did exactly that. Recommended.”
Dillon, Tucson
Standard ABS, FDM
“I'm amazed at how quickly you turned this around and they look excellent. ”
Kevin, Englewood
Standard PLA, FDM
“Very quick service and the quality was exactly what was I was looking for. Thank you very much.”
Steven, Aurora
Standard ABS, FDM
“Excellent communication. Sent pictures of test and example prints before shipping. Responded to questions about desired appearance and how to get the finish I was looking for. Very timely communication and beyond-expectations support and assistance. Made my first time ordering from them an excellent experience. Would definitely recommend. ”
Jackson, Denver
Metalfill PLA, FDM
“Fantastic service and careful attention to all my requirements.”
Graham, Aurora
Standard ABS, FDM
“A+++++ Great communication and super item, packed well and delivered quickly. Thank you!”
Neil, Denver
Standard ABS, FDM
“Job was done as requested and in timely fashion”
Meredith, Denver
Standard PLA, FDM
“Excellent communication and product, prints looked better than I expected!”
Randon, Denver
Standard PLA, FDM
“Andriy did a great job communicating his different processes and delivered beautiful results.”
Max, Denver
Clear resin, SLA/DLP
“A great service provider to work with. Would highly recommend. ”
SANJEEV, TUCSON
Standard PLA, FDM
“Excellent service. Thanks for the quick turn-around and quality.”
Harry, Broomfield
Standard PLA, FDM
“Part came on time and built to spec! Very happy with the whole transaction!”
Robert, Lafayette
Standard ABS, FDM
“printed quick and parts as expected. great experience!”
Allen, Amado
Standard ABS, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
