3D printing service DC
Our 3D printing capabilities
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in DC
SLS 3D Printing service in DC
MJF 3D Printing service in DC
SLA 3D Printing service in DC
Over 289 customers are satisfied with our 3D printing service.
“Easy to do business with. Great communicator. Keep me informed during the entire printing process.”
Thomas, Washington
Standard PLA, FDM
“Great! Everything came as expected and super fast. I would definitely order from this maker again.”
Megan, Washington
Standard PLA, FDM
“Great printer. Knowledgable, happy to help, great to work with. Very fast!”
Nicholas, Washington
Standard ABS, FDM
“Excellent prints, would definitely use again!”
Lex, Washington
Standard PETG, FDM
“This turned out even better than I expected! Excellent work!”
Joe, Washington, DC
Standard PLA, FDM
“Great prints, outstanding communication. ”
Jesse, Washington
Standard ABS, FDM
“Great quality and customer service, as usual.”
Phil, Arlington
Standard TPU, FDM
“very fast, no trouble at all, and a great result -- thank you!”
Tim, Alexandria
Standard TPU, FDM
“Great work. Excellent print and great communication. Highly recommended.”
Philip, Arlington
Standard PLA, FDM
“The parts look great and arrived very quickly!”
Robyn, Silver Spring
Standard ABS, FDM
“Great job and communication. I am very pleased. ”
AJ, Bethesda
Rubber-like resin, Material Jetting
“Great quality print and was able to pick it up within 12 hours of placing the order Excellent!”
Demby, Alexandria
Standard PLA, FDM
“High quality print, and I was able to pick it up the same day I ordered it.”
Lucas, Alexandria
Standard PLA, FDM
“You did a good job, fast and clear/clean, thank you.”
Emil, Beltsville
Standard Nylon, SLS
“received quickly and work was high quality”
Peter, Potomac
Carbon filled Nylon, SLS
“Quality is excellent, and customer service was unbeatable--actually turned it around in one day, faster than promised. Highly recommended.”
Matt, Olney
Standard ABS, FDM
“Great communication and wonderful print quality!”
Eric, Laurel
Standard ABS, FDM
“Absolute first rate service. Communication was excellent and print was perfect.”
Jason, Burke
Standard PLA, FDM
“Excellent work. Optimised toolpaths created strong parts.”
Jeremy, Savage
Standard PLA, FDM
“Thank you for the very quick order! It came out great”
Leon, Gaithersburg
Standard PLA, FDM
“fast and excellent quality and customer service. I will order something from you in the future.”
libo, clarksville
Standard PLA, FDM
“Very friendly, helpful, and insightful. Completed our order quicker than estimated by them.”
Nhat, Fairfax
Standard ABS, FDM
“Quality parts and quick service. Thank you! I hope yo use your services again.”
Ross, Columbia
Standard PLA, FDM
“Excellent customer service and quality of print!”
Colin, Columbia
Standard PLA, FDM
“A++++++++++++++++++++++++++++++++++++++++++++”
Nate, Fairfax
Standard ABS, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
