Apr 2017
Hi really hoping someone can help. My Zprinter 450 no longer boots, when i turn on the machine it beeps 3 times pauses and repeats. There is also no text on the LCD just a blank white box. If anyone knows what the beeps mean or if there is anyway of running a system check that would be greatly appreciated.
Thanks
Aaran
3 beeps generally indicates a RAM error on the motherboard.
I would also inspect the board and power supply for swollen or leaking capacitors.
If you have not done so already, making a backup of the hard drive is a very good idea.
Good luck and let me know if you need general guidance.
Hello,
You would have to reset the motherboard.
You would need to plug a vega monitor and keyboard.
Reboot the printer and the setting will load on the monitor.
Email me and I will send you the doc to reset the mother board.
If that does not fix the issue then your motherboard overheated and damaged the CPU.
There is a fan on the cpu make sure it still works.
Over time that fan will give out. We had this issue before.
Hi, Thank you both for the reply. I’ve now fixed the problem it was a dead stick of Ram. I’m now back to the original issue i was facing before i posted on here. I keep getting HP11 continuity check failed error code 40800, I’ve already thoroughly cleaned pinheads, pogo pins and connectors. Tried multiple new pinheads, bought a new pogo card and carriage ribbon cable but to no avail. I’ve manually checked most of the cables on the machine for continuity but everything seems fine.
Hello, May I ask you the documentation that you were proposing to Aaran to reset the motherboard? I bought recently a Zprinter450. I had recently to change the battery of the motherboard. Since then once the printer is online, as soon as I connect it to a router to put it on the network, the printer hangs up and does not react anymore. May be that the motherboard needs to be reset. I would really be happy if you could share this documentation. Today I am pretty much stuck and I did not have yet the chance to print any single part. Kind regards Mourad from Switzerland
1 month later
1 month later
1 year later
