Fixed it! Turns out the cables had become loose in the back, which was causing the malfunction. I must have jostled them when I was moving the printer from where I set it up to the workbench. I used it for about 12 hours yesterday, and everything seemed great.
Thank you all so much for your input and help. I’ll be back in touch, for sure, if I run into anymore problems. Maybe one day I’ll be able to help solve some of them!
The new flatcables are more durable than the older cables with the mesh. They are expensive. I never saw any alternative cables. You must be carefully to not short the motherboard with the wrong cable.
I opened the cable. Actually Zortrax reroute the different color cable. I successfully use a normal cheap Computer rainbow cable with an adaptor from Zortrax. It works perfectly. However, the problem is I still have to buy the adaptor from Zortrax.
Replace your ribbon cable. We just had a similar issue and this fixed it. Maker sure you have your ribbon cable secured up the back so the radius of curvature doesnt get too small.
100% it is the ribbon in this case. I had the exact same problem, and I ended up at this post a month ago. I ordered a ribbon from Amazon and it did not work (did not even power up afterwards). I ordered a ribbon from Zortrax this past week, and it just came in today, and it worked. It is not the hot end specifically because the gear sticks without any filament in it. So, it has to be something with the gear or something controlling the gear. I first tried what the poster said by checking my connection, but no luck. I took the thing apart and looked at the gear for crud in it. In the end as soon as I turned the unit back on with a brand new ribbon it was good to go. It is crazy that I maybe have 80-100 hours worth of print time and have to put a new ribbon on, but oh well.
Same problem here. 100% sure the extruder cable. I’ve been able to solve it with some tires. I suspect the problem is in the connection and not in the cable.
