Mar 2016
i use Autodesk Fusion360, this is a great, powerful software for beginners and experts. All of my CAD is done with this software. It works on PC and Mac, and very affordable.
Hi Chris,
I use Blender as it is very useful, but can be a bit overwealing at a first glance. It is brilliant and you can get it for free. You should definitely look into it. It may take a few hours to learn the basic, but it really does pay off. If you have had experience with simple CAD like SketchUp then it is a good place to move onto. It may be used by beginners and pros. I would definitely recommend Blender.
Hope this helps!
I suggest you use Onshape www.onshape.com 4 - it’s a FREE CAD package on the cloud from the team behind Solidworks.
It’s much more powerful than sketchup, ideal for engineering design.
+1 For OnShape. It’s very good. If you know Solidworks, Cubify or Geomagic, you are already ahead of the learning curve. Otherwise it’s very easy to pickup and there are tons of resources developed by OnShape to get you up to speed. Minimal computing resources required - as long as you can run Chrome and have a decent (I have 15Mbps and it works fine), you are golden!
The only down side for the free version is that you are limited to 100MB of private storage. This gets eaten up very quickly due to the history feature of OnShape. However, you do get 5GB of public storage which is okay if you don’t mind sharing your designs with the world. These restrictions can be removed by purchasing a license for about $1500. Cheaper than Solidworks but very expensive for a hobbyist or small privately funded startup.
Thank you all, its been very useful, alot to take in tinker with, until finding ones you like. , what about pc spec, 16gb ram, 8x 2.3 gh quad processors graphic, setup, whats basic spec, min for all design programs.
thanks chris
I did notice that there was a lot of talk about programs, but little about hardware.
The requirements for a PC will vary depending on how complicated you want to get. Are you a hobbyist, professional? Some programs will not use above 4GB or 8GB of ram. Knowing your software requirements can save you some money (that being said… 16GB will never hurt).
I would focus more on the graphics card. Put your money here. It is most noticeable when doing something like rotating your model. Some of my more complex models have dropped me down to 1 frame a second (very slow rotate), but then, I don’t have the fastest video card. If you decide to use a program like Blender (which I use), stick to an NVidia card since that is the only one that’s fully supported. Again - know your software requirements and recommendations.
Once you decide what software you might want to try, look for requirements and recommendations from the producer. For example, Fusion 360 has a requirements page 6.
It can be confusion and please note that you never really want to go with a minimum requirement. It will be cheaper and it will work, but it will be frustrating because it will be slow.
