I also have a RAMPs board but I stack a second 5/3.3 volt regulator on top the first to help handle the extra I put on it, servo control, fan controller, dual extruder with a heat bed, Bluetooth connection, filament sensor and a full graphics. However the MCU is too slow to handle most of it while reading an sd card so octoprint or a computer helps there to take some of the load.
Does research say anything about how the melzi board is a knock of a RAMPs 1.4 or ultimaker board? Cause that’s where gt2560 came from. Tom Schindler something did a review on it. Board quality depends on the manufacturer of the board. Some China supplier will make it themselves in there garage and resell on ebay, with at times the incorrect assembly process. Please just find a board that meets your requirements. Look into the manufacturer of the open source design. The ground connection is over heating due the the rating of the plastic connector. Most are only rated 10amps usa or “15 amps” outside of usa and have that cl listing and no UK something listing. They are different and they also run different voltage and Hertz. 220-240 @ 50htz. While we run 110-120 @ 60htz. Small things can make a difference in some areas. I say voltage cause so many skip that small line of instructions and don’t flick the psu from 220 volt to 120volt.
Tom Sandladerer. I disagree with your use of the term “knock-off”. These boards are all open source. And it’s more of a generational progression. GT2560 is RAMPS but improved. Unlike where things would be covered by patent law and then you be knock-offs.
GT2560 is a generational improvement on RAMPS, not a knock off. There’s a difference. Heat sinks aren’t an issue as far as I’ve seen, owning both a RAMPS and GT2560. GT2560 works fine without heat sinks.
On top of that, the direct 24V compatibility is a plus as the lowered current generates less heat and does less damage. Besides, you can run it at either level.
I don’t think anyone said Prusa wasn’t open source, never heard such a notion in my life!
I can’t ever remember his last name, thanks for that. I used knock off in the context it was being referred to at the comment, in response. I agree with your statement of open source hardware. Not a knock off in most cases. More like “kinda” a knockoff situation on some out there. However, the gt2560 was never “open source” technically as they at the time did not release the schematic and layout for PCB. Like other open source boards. But I assume you have never pushed a heatbed to 300 watts or adjusted the pid loops on your own machine based on your answer of never having an issue with the MOSFET cooling as they are rated far above what they are used for if one incorporates Infinite cooling, which is near impossible. Your rate of heating depends on what MOSFET was Installed by any one of the manufacturer. And the firmware being used. The person designed it based on (The ramps 1.4 as the state in wiki page they link to from there site). I Skype with him here and there. Do a little more research dude and you will see what I mean. And if you also have provided personal Input of the newer version. Like adding back ing the open pins so that others can add things like a servo or Bluetooth or filament breakage sensor or a measurement sensor like I put and Incorporated in my own i3. Others stated that Joseph Prusa newest version say not open sourced in other comments below. But I stated he took open sourced ideas and improved on them and said if you look it’s actually there they just don’t make it easy. Have you seen toms latest video of when he interviewed Mr Prusa about the new quad color upgrade? You may want to listen to what he says there. I k ow this comes off wrong so my apologies now. I only am stating what I know and learned on my own and may be wrong as information does change from time to time anf is hard to stay up to date o “everything” at once. So have a good day/night dude.
The 24 volt is not really set up correctly. As it puts out 24 volt to everything instead of 12 for the fans. And is or can be finicky at times. 3d printed life is building another machine and has stopped using the gt2560 for that reason. The Rambo board can have up to three different voltage Inputs for the bed, extruder and stepper, etc. That’s the board by the way that is the actual generational improvement of that board, again, designed by ultimaker, who also designed the ramps and ultimaker board and a couple others that I just can’t remember at the moment. But yes, double the voltage and amperage is cut in half. Simple ohms law deal. All about the watts. Lol.
At least GT2560 is still readily available at a decent price.
youre right, I haven’t tampered with that simply because I’ve never had to. My printer has printed everything I’ve wanted it to with minimum issue for a sling as I’ve had it, so no. I do know what you mean, first thing I did when I got my RAMPS was compare all the important components to the official schematics.
I haven’t done any serious mods like Bluetooth or filament diameter sensors because I don’t have to ATM, though may add a filament end sensor at some point! Got it hooked up to Octoprint though, rather enjoyable, printing across the country.
Yeah, I agree with the Prusa team statement. Lulzbot do the same, they have a beautifully laid out website but the source files you really want are ambiguously hidden away.
I did see the video and I did listen! Though it was half-heartedly because I was also getting some work done.
Hahah don’t worry! Your demeanour is pretty cordial
