Hi Mike,
Thank you so much for your time and advice!! I really appreciate it
I’ve had a play with one of those pens before and unfortunately they are extremely tricky/ should be left to the professionals
Francesca
KCT
15
before i say yes…were is thou home located ?
KCT
17
oops…i,m located in the netherlands…if id seen it sooner…
but won,t be able to get it there before thursday…
How about you @Marco_16 @ are you able to help Francesca with her print? Cheers
Hi I’m also in Coventry! I’m currently downloading the model and will get back to you if I can print it!
George
I’m down near Coventry and most likely could get them printed if they are able to be printed on fdm machines and posted to you by Wednesday/ Thursday.
That would be brilliant if you could ! did you read the below comments about the correct scaling etc?
Message me if you need more detail/info on the project!
Great! How about it, @frankiecheska? George, keep us updated on the 'if’s
I will, sorry my internet is so slow it’s taking ages to download the file. Also by how much can I upscale the design?
George
Anything that fits into 45mm3 is fine !
Francesca
Ok I will try one now at 2500% original scale which is slightly over 4.5cm3 but will give us an indication. My gut instinct is that the poles may need to be thicker. I’ll see though.
okay, there is leeway with the pole thickness also if that helps.
