Only 6 hubs (myself included) reviewed it this year. It finished top with 9.2 but obviously not enough reviews to be considered for the list.
It is an amazing printer. I’ve has a few and I still have an Up Mini and a CEL Robox but the UP BOX is in a different league. I think next year, when more printers are out there, it could be the outright winner on 3D Hubs.
I should add that mine runs all day long with hardly any maintenance.
have had the UpBox for about 8 months, and the only problem I’ve had was with the extruder which was replaced under warranty (the nozzle was the wrong material and got seriously blocked), apparently a fault they new about.
Otherwise no complaints, have had no problems using PLA, just use the settings. have also tried flexible and that worked too, just be careful with the temperature.
more than happy with the UpBox thinking about getting another to work alongside.
that’s just what I was going to reply, you beat me to it.I have not used either myself as I am more than happy with the way it works at the mo. might try the hack tho.
I got mine from a UK shop but it came from the UK distributor. I believe upgrades have been made so I would get it direct from UP if possible. That way you know you are getting the latest machine.
I’m a little late to the game here but I had just purchased the Afinia H800/UP BOX when Yakiimo posted this question. I wanted to get a few months use out of the printer to give a more experienced opinion. There still aren’t many reviews out there so I’ve put together a review of the printer after a few months of professional use. For anyone interested in this printer take a look :
Very helpful review. My experience mirrored yours almost exactly. Especially about the auto nozzle height problem - it puts the nozzle too low and causes a clog for me every time i have tried it. It’s too bad that it makes the feature pretty much useless for me. I hope they will fix it in an update. Alternatively, I may try putting some layers of tape on top of the auto nozzle height mechanism to induce an additional offset.
I did have one very different experience from yours - I can’t print with the “no raft” option. I tried it and the software or the firmware seems to treat the bottom layers as raft material even when “no raft” is selected. So the bottom several layers come out with the sieve effect. Support told me “please do NOT select this function to print”. Have you successfully printed without a raft?
– update up3d support claims that my nozzle is too high and that actually the No Raft option is viable. Not sure if I will try it with all the clogs I’ve had.
Not sure if you’ve ever seen this but PEI works REALLY well as a print surface. It becomes ultra sticky when the bed is heated and once cooled the printed parts pop right off.
Thanks for the advice! I recently got a 0.4mm drill bit so I guess I can experiment with dropping the nozzle. I have seen everyone talking about PEI so I may try that out - what would you do? Remove all the screws from the aluminum block, attach glass and then the PEI? That sounds appealing because for the life of me I can’t get zeros across the board with the Up Box platform.
