Aug 2016
I have a printrbot simple metal that worked perfect for about a year then i read somwhere that u can clean the metal bed with 70% alcohol, anyway after i cleaned the bed my paint peels off during long prints but the filament is stuck like glue on the tape!! please help i have tried scuffing up the bed with sandpaper
    Aug '16
    Sep '16
  • 10
  • 5.9k
  • 7
Plain Glue Stick. Works great below or above the tape. For some reason alcohol & blue painters tape cause extreme adhesion to PLA.
-Jesse
Hi there! So you cleaned your print bed with rubbing alcohol and now you are having issues with the painters tape sticking to the bed? I’ve been using blue painters tape, rubbing alcohol and glue sticks to get prints to have great bed adhesion for a few years now. My process goes like this, get the tape down and smoothed, then I rub the tape down with the rubbing alcohol, then right before printing I put some glue stick down on the area being printed on. Works flawlessly. I think your issues is wiping down the metal bed itself with the alcohol then still using the blue painters tape. That would effectively do nothing but clean the surface you are putting the tape on. But rubbing down the painters tape with the rubbing alcohol you remove dust, dirt, oils, and it creates a much better area for the filament to adhere to, and the glue stick really helps that as well.
Not all painter’s tape is the same. Some have poor adhesion compared to other types. Some have so much oils in them that as Sully has suggested it is best to wipe down the tape with isopropyl alcohol after you have applied it to the bed. You don’t really need to clean the metal bed unless there is a lot of tape gunk stuck to it.
I would recommend purchasing a printinz board and ditching the painters tape. I use those boards on all my machines now including my printrbot simple. If a print ever gets stuck to the board all I have to do is remove the board and bend it lightly to pop the print off. On the other spectrum if a print doesn’t stick properly a little bit of glue stick goes a long ways and I don’t have to clean my printinz boards of it as frequently as I had when I was using painters tape and glue. Those boards have saved me money and time with not having to deal with painters tape.
Hi there, you could do the same thing by setting your Z Offset in your printers gcode. I believe printrbot actually has an article about this for setting up Cura.
