When using the Ultimaker 2 i get this print bed issue which is to do with the temperature sensor, it seems to work when i switch the machine on and off a few times. Sometimes it even happens when i reduce the print bed temperature to 0 when using PLA. I was jsut wondering if anyone had encountered this problem and if so how to fix it, i assume it is probably my fault but not configuring something correctly but still frustrates me to no end. All comments are graciously welcomed!
You might also want to keep this guide to troubleshoot your prints.
key23d
3
or contact Ultimaker if you haven’t done that already!
I haven’t had the problem (yet)
Kind regards, Guy
Thanks Guy will check out what @ProdPoint posted and see what the next best step is.
