Feb 2016
I can’t help you with your questions on Ultimaker original or Go!. However, I’ve been using an Ultimaker 2 extensively for the last eight months, which worked fine straight out of the box. I’ve taken it into a number of schools and it’s always worked well. Ultimaker 2+ (which I’ve seen in action, but don’t own) looks to have improved performance in a couple of areas. The new ability to change nozzle sizes is particularly interesting. You might look at Ultimaker’s CREATE site. They take the educational sector seriously, so you would have good community support
I have had the UMO+ for over a year, and only recently had to repair it, due to sloppy use and ham-fisted maintenance by yours truly. In my experience, this printer is consistent, and does not require adjustments unless you change the parameters. It has allowed me to learn 3D printing by showing me the results of every error that I’ve made in a consistent and predictable manner. (Or, it would have been predictable if I had had the experience needed to predict it.)
Perhaps have a look at this video from tested.com the guys associated with mythbusters.
For a learning environment the umo+ us a great piece of kit. Great printer (i have 2) and in a school environment i would think pla rather than abs. Very adaptable and reallt shows off what is happening in the process. Other printers take away some of the skill needed, so if you want plug and go then um2+ if you want to play then umo+ …both will produce good prints & have great forums/community & spares/upgrades. If you stick to pla then no heatbed needed (though useful for nylon, xt, ngen, filaflex etc) Good learning platforms (have had mine 3 years and worked them hard, dont be fooled by the timber frames, these are tough workhorses).
I bought an Ultimaker Original and updated it with the heated bed (=UMO+). I never had maintance problems. You can print up to temperatures of 255°C. I also built a box around the printer to assure a stable room temperature. The printer prints at his best when room temperature is about 20°C.
Regarding safety… One of my mate who has an up box 2 complains that you have to wear safety gloves to remove objects from the up box 2… Cause you can get cuts. I was wondering if that was true?
Cause the UM2 doesn’t require any effort removing especially PLA cause of the difference the glass plate cools along side the plastic.
Please have a look at the Felix printers, they are of a totally different mechanical quality level. There are base models which you can assemble yourself up to the top model with auto bed leveling and dual extrusion. Software is good and the printers are open source. I found the direct extruder much more reliable than the UM bowden setup. UM is nice but there are so much more modern printers on the market. Someone mentioned the Zortrax M200, very good but hardly suitable for tinkering.
We have 2 Ultimakers and a CubePro Trio. The Cube Pro is so robust it is like driving a tank. The Ultimakers are so fragile its like holding a butterfly. We are always doing preventative maintenance on the Ultimakers.
The only disadvantage of the Cube Pro is that it is not competitive because of the higher material cost.
Our Cube Pro is 1 year old and we are selling it at almost half off retail
Get the UMO+ kit for sure!!! I do not think the UM2 is worth the extra money, especially since your a school and want to have the experience of building you own, the UMO is more hackable too.
I work for a school district in Michigan and have been supporting Elementary and High School 3D printing at my district since 2013 and I would without hesitation recommend the Ultimaker Original Plus Kit for your schools. We initially tried several other printers but quickly saw the major quality issues and high maintenance issues of the other brands, at the end of the 1st year we standardized on the UMO+ and have been supper happy ever since. At this point I have helped schools put together over 20 of these kits. I actually run a weekend long work shop 1 to help schools get started. SO here’s my rational for the advice I’m offering you.
As anyone (who is not a sales person) will tell you there is no 3D printer out there that will be maintenance free and this is why I strongly advise you to consider a Kit printer. I have found crucial component to an active program is empowering building level people to run their own print jobs, do basic maintenance, and troubleshoot any issues. I have found over last few years that the absolute fastest and best way to create this building level expertise is to have a local team of 2-3 people (MS and HS kids could be part of this) assemble the printer from the ground up. This way they have first hand experience and understanding of how the printer works, how to run print jobs, and how to maintain the printer.
I have seen other kits and many require soldering, using many different tools, and many hours of build time. The UMO+ kits are beautifully engineered and the finished printers strike a wonderful balance between high quality and hackability. Team members only need to use basic tools such as a pliers and a screwdriver. There is NO soldering, NO wires to strip, NO saws or power tools. Total build time averages between 18-20 hours.
As I mentioned in my personal experience the UMO+ is by far the best for schools and clubs…as in… most accurate, fastest, easy to maintain, low downtime, large enough build area to keep up with a class of 25-30 kids, great support, very active global community, immaculately engineered, fully open source (no limits to the learning potential due to trade secrets), the box shape helps keep kid’s fingers out of the way, easily put on a cart and wheeled down the hall, winner of many 3d printer awards over the years, including MAKE: Magazine’s Most Accurate and Fastest Award, and Best Open Hardware Award. To sum up, the Ultimaker printers strike a perfect balance between reliability, durability and cost. They meet the most important selection criteria (for schools) IMHO:
1. Low downtime and everything end user serviceable. (When the printer is down no one is happy.)
2.Precision and accuracy (To insure that all kids get a good print of their model, the 1st model should be just as nice as the 500th model)
3.Speed and Build Volume (When printing for a class of over 25 kids, you need to print several objects at a time. The 8x8x8inch build volume allows for that.)
4. PLA printing (non-toxic fumes and bio-degradable) AND OPEN filament - as in you do not have to buy over priced proprietary filament from the manufacturer.
5. Open Source (No limits to student’s involvement and depth or tinkering.)
These above 5 points should help you evaluate any other printers that are out there.
ALSO - do your homework. Check out the forums where users of the printer you are considering are collaborating, and helping each other. DON’T just read the ads and look at the price.
AND AND - make sure you save $ for PLA, you’ll want a bunch of that. And make sure to get off stuff, like ColorFabb, don’t get cheap stuff since the quality of the PLA directly impacts you ability to get good prints. The High School class I helped develop (1 semester ~25 kids , uses about 4KG of plastic each time).
I love my UMO+ self build, and it has really been a joy to use these last 1.2 years. I have had to do very little maintenance and it has so far managed every material I have thrown at it - flexible, Copper/Bronzefill, all the weird Parthy filaments from Formfutura, conductive, laybrick, PETG…I have really tried a whole lot and it has been so consistent, not even a single blocked nozzle. I also make my own filament now, and even though some early batches were miserable (diameter variations between 1.9 and 2.9) it has performed consistently. As long as you follow the recommended protocol and maintenance (oiling the bearings, pre-heating the buildplate and nozzle, using gluestick) it works like clockwork. ABS is sometimes a challenge because of the warping and fluctuating temperatures, but that’s the same for all open sided printers - plus it smells really horrible, so would not recommend using it around kids anyway, enclosure or not.
Hi. Ultimaker ORIGINAL + would be the best selection in that case.
It is not difficult to assemble and is a good way to learn more about the technology while doing it.
I own a UM2 and it’s a great machine, but I don’t think I would go that high for something that will be run in a school. I’ve worked with a couple of local schools and found the XYZ series to be more affordable and they’re quite dependable machines.
I would start by familiarizing yourself with the top printers, Maker magazine puts out a review every year.
Wow! many thanks for all the replies, I’ve got some reading to do!!
I did scan some of the responses, I am in New Zealand so would prefer to buy local as the tax becomes a deductible. If I import we can’t claim the tax as a business expense, but I am going to have a look at some of the suggestions, who knows, sometimes these things work out cheaper when you import.
For the price of an Ultimaker you can get 2-3 Flashforge Finders. This amazing little printer is by far THE best choice for schools. It is really plug and play, has WiFi, it’s more quiet than ANY printer around (meaning: you can actually have in sitting in a classroom without disturbing the ongoing lessons), assisted calibration, filament run-out detection, lovely big full color touch screen and a well protected hot-end (safer from damage or people burning themselves!). What’s not to like? As for Ultimaker, never ever buy the kit for school purposes, the idea is that you print with it and not tinker. The UM2+ is in my opinion far too expensive for educational purposes, the build volume too large (schools don’t want to print big things, but more small things), it has a very small text only screen, no WiFi, a quite a learning curve in comparison.
But most importantly, ANYONE can quickly start working with a FlashForge Finder, any Ultimaker (or just about any other printer) requires time, and experimentation. In a school, a printer should be easily accessible by all, and that is what makes the Finder stand out.
So if you want it for your own fun, by all means go tinker and experiment, but if the goal is that teachers use the printer to aid in their lessons without much fuss, just get the Finder.
