Jun 2015
Rotating the model by 15 degrees gets rid of the artifact. The discussion as to what the problem is, and what a better solution might be, continues on the Ultimaker forum! It appears to be something to do with the stepper drivers. This photo shows a print done at the Normal (.1mm) resolution in Cura but turned by 15 degrees on the build plate. No more zebra!
2 years later
I printed my first 3DBenchy to mark 2666 print hours on my Ultimaker 2+, and got exactly the same lines as yours a few years earlier. I can tell you it’s not infill, that’s for sure.
