Jul 2016
Ok, I’ll try to buy one during the weekend. In any case, it’s a good tool to have in the lab
I don’t have experience with UM2, but it makes sense to remove the hot end to reach the isolator coupler. I have UM1 which should be about the same.
After you do all the easy checks…like making sure there are no stringy bits binding the filament in the bowden tube, and after checking and maybe cleaning the extruder gear, and trying a different nozzle…I would think that it is likely to be the teflon coupler that needs replacing. They are a consumable item and I have been through a couple.
Try to put a litlle bit of WD-40 inside the bowden tube, it as solved my extrusion problem with the Ultimaker 2GO.
Regards
Marc
infrared thermometers will not give you an accurate reading. you need a thermistor to check temps.
