Jan 2015
I do not agree with your last point. When you’re saving a model in Cura it will be saved as a STL file when you put .stl at the end. If you don’t add .stl it will be saved as an AMF file.
Now you can delete the last point from your “Annoy List” :slight_smile:
Thx that’s true I should have try that but wrongly assumed the proprietary extension was associated with a propriatory encoding. But why not offering the options in the user interface instead of hiding it for the end user to find it by chance or by try and error.
I should also says that Slic3r do have this functionality as Export STL button on the GUI. Sorry if you felt offended but this is not an “Annoy list” The comment clearly stated few missing feature and not things that a re missing that I’m bothered by. :wink: Unfortunately comment are not editable otherwise I will have amended the list.
