Jan 2016
Hey
Both my thermocouplers no longer give reading, but im really struggling to find replacement parts.
Where can I source new thermo readers for the CTC 3D printer?
    Jan '16
    Jan '16
  • 14
  • 1.6k
  • 7
Search for a Type K thermocouple on eBay. You can use those.
I had a look at biby3d but couldn’t see any ring type thermocouples, only the ones which screw straight into into the heating block
anyone tries one of these instead of the ring type ?
Basicly the lug screws into the hole the ring type was mounted. It seems to be the newer prefered method, both MBI and Flashforge have switched to these. You need to ensure the lug is M3 to be compatible with your block. Here is one thing that you may find, with the lug type sensor you tend to set your extruder temps a little higher. This is due to the lug type being a better heat conductor. While sensing 210 at the end of the eyelet type, the screw holding the eyelet might actually be 215.
B3D - Thermocoupler (K type) as used in Replicator 2/2X Details would be the one
