mrtaro
December 6, 2016, 9:00am
4
I found a material “ABS M30i”, which seems to be biocompatible. Can i autoclave it perhaps?
Not sure what you are planning to use this for but even if it is sterile, ABS can leach out chemicals into whatever it contacts.
zx81
December 6, 2016, 1:00pm
6
FDM type 3D printing is not considered for safe because of the layers and gaps associated with this type of printing there are some good resources online just look for 3d printing and “food safe” Is this for some sort of “body modification” (just guessing as autoclaves are commonly used by piercers and tattooist’s) UV can be used to sterilise but it does break down some plastics such as ABS
mrtaro
December 6, 2016, 1:01pm
7
Thank you for the input.
My purpose is to 3D print a free form that will come in temporary contact with wounds. Thus it needs to be clinically sterile before use.
Therefore, i would appreciate if someone could give me hints on what printing technology i should use, and what material, in combination with an effective sterilization method.
zx81
December 6, 2016, 1:35pm
8
Well you could coat the 3D print in a good food epoxy that will seal the print then sterilise the outside of the print epoxy is pretty hard wearing, or you could use the smoothed print to make a cast of the part (depending on its complexity) and from that you could make the object from a different material resin / latex etc
autoclaves arent just used by piercers and tattooists. Hospitals and clinics also use autoclaves.
Enza3D
December 6, 2016, 4:05pm
10
Formlabs Dental SG resin is a Class 1 biocompatible material (it’s the only consumer available 3D printing material I know of that is directly approved by the FDA). This resin is also designed to be sterilized in an autoclave, so it might be worth looking into using this; it seems like a good fit for what you want to do from the vague descriptions. More info can be found about it from Formlabs’ website , or reach out to them directly.
Regarding the ABS M30i, I’d suggest reaching out to Stratasys and see what they have to say regarding autoclaving. It would be a much better material choice in terms of strength, so it might be worth it to use an alternative sterilization method.
I would second this. Biocompatible materials are still mostly relegated to high end industrial machines, but the Formlabs Dental SG resin is probably the most accessible and available bio compatible material for consumer printing. If you contact a Hub with a Form2 printer, they might be willing to special order that resin for you (if they do not already have it), but it is pretty expensive stuff comparably. Best of luck!
Enza3D
December 6, 2016, 4:33pm
12
It is a resin I only stock for special orders because of that price tag. But from what I’ve seen of it, it prints beautifully and works exactly as it is designed to.
zx81
13
Did I say “only used by”?! I said “commonly used by” big difference… besides when you see hospitals and even vets using 3d printing is usually done in titanium… so when I read the original post I thought it might be some 3d printed Piercing type jewellery.
I’d second the use of resin designed for this purpose. Just about any thermoplastic you can print with (except PEEK maybe, and not many printers print this) will deform at the temps you’ll want to autoclave, so I’d say FDM printing is out. Polymerized resin should handle this much better and should also have a smoother surface with less gaps for bugs to hide in. Quite a bit more expensive than FDM but that’s medicine I guess.
Perry_1
December 7, 2016, 12:15am
15
You can print with Taulman nylon. Can be sterilized in autoclave. See their website.
mrtaro
December 7, 2016, 2:03pm
16
Thank you for your input!
I sent a mail to Stratasys regarding autoclaving the ABS M30i material. I found on another page that autoclave will damage ABS M30i…
Formlabs Dental SG resin looks like a very good choice. I will mail them and ask what equipment they use.
Kind Regards,
Chris
Enza3D
December 7, 2016, 2:06pm
17
Formlabs resin can be printed on any SLA or DLP style printer; Formlabs will most likely recommend the Form2, which is the printer I use. I highly recommend it.
Sterilization like for a medical device?
I think this is something you’re going to have to experiment with. Radiation (Gamma or E-Beam) will cause embrittlement and color changes in most plastics as there’s a lot of cross linking of polymer structures. Some people tint polycarbonate plastic an ice blue color because it will turn a sickly yellow otherwise.
I can’t offer anything about Ethelene Oxide except it’s not very practical in small batches, and autoclave is probably not an option for any thermoplastic you can print.
Regards,
Matt
Perry_1
December 7, 2016, 5:03pm
19
Contact Taulman 3D directly and discuss your plans with them.
Enza3D
December 7, 2016, 5:42pm
20
As others here have said, SLA or DLP is far better than FDM printing if you want to reduce surface defects. FDM will leave large spaces for contaminants and bacteria to grow within, but the resin produces a much smoother surface at a microscopic level.
mrtaro
December 12, 2016, 10:07am
21
i just noticed that we have a Form2 in our lab … initially i used PC-ISO…
Hi, I know for a fact that you can use PA2200 which is a nylon powder used on EOS Printers. This material can be sterilised, using various methods. Definitely worth looking into, but you may want to have a look around because if it is going to be in contact with an open wound you will want to make sure the manufacturers have the relevant certificates and conform to standards.
caizio
December 26, 2016, 5:10pm
23
We’re currently working with both ABS and PETG for a blood-contacting device that will be sterilized prior to packaging. So, we’re needing both sterilizability and hemocompatibility. Depending on your final application, you may want to look at PETG, it’s compatible with both gamma irradiation and EtO (ethylene oxide) sterilization methods. If you need to go with autoclaving, then you may want to look at nylon as it can handle the higher temperature.
