Sep 2016
After unpacking the M200, there was a white strip dangling in the front open space of the machine. It looks like a strip of soldered bits stuck to a plastic strip and contained in a half-tube of silicone. One end is fastened by black tape and then to a series of thin black wires. The other end is just cut with 3 metal prongs.
I have a bad feeling that this was cut during shipment. :frowning:
    Sep '16
    Sep '16
  • 13
  • 1.2k
  • 9
Usually, they are really efficient and they will probably reply you within today.
@federico3, on a side note, the serial number is located on the back, but I am not sure which number it is.
Is it the one under the bar code on the back of the machine?
That strip is an LED strip, which lights up during printing.
If you just stick it to the frame inside the front face of the case at the top, you should be fine. probably just came off in transit.
Hi Shannon,
This is just the led strip that got loose after assembly, prabably during transport. If the black tape still sticks you can just stick it back on the printer and you should be all set.
Wow! Thank you everyone for the quick responses.
You guys are truly awesome. I am defintely feeling better now. :slight_smile:
The strip is just LED lights. Cool.
