Aug 2016
I am a huge UM2 advocate and when I came to choose another printer I got a second one the same.
Only thing I would comment is that you mention Ninjaflex and this might mean you’d be better off with a direct extruder rather than Bowden tube feed.
Very true. I’ve printed plenty of ninjaflex on various UM printers and having the bowden is a disadvantage but you can do it - you just have to learn some tricks and you will end up printing much slower but you can do it. But if I were going to be printing a spool per month of ninja (or more) I would seriously consider getting a different printer. They have a “cheetah” filament that is even easier to print now by the way. Not quite as flexible.
Thanks for the heads up. Luckily i don’t mind tinkering around! Maybe should go with less flexible materials like flexible polyester from plastic2print.com or as you mentioned Cheetah or Semiflex. Seems to me they have better surface quality too because of a wider T_g range.
