Jul 2016
Just got a makerbot replicatior mini. Tried to print stuff but printer gets stuck at “position found 77%” every time, and does nothing.
I have tried these things
- updated firmware to 1.11.0.541.
- tried newest MakerBot Desktop on WIN7 and Linux
- reset to defaults
- take off the extruder and put it back
- created new user profile (tried friends profile too)
- tried bunch of different files
Any ideas
have you tried a different file to print? is your printer connected directly to a workstation or printing form an SD card? i am not sure the MakerMini uses SD card option because my Rep2x has that option. In my opinion though Makerbot has good printers but in my experience i had so many issues this is why i sold mine and bought a MakergearM2.
Try using a different SD card, reformating the SD card and/or printing via usb. I’ve found that sometimes I need to reformat or swap out cards.
Is this a new Mini with the SmartExtruder+ or the original SmartExtruder. Easy to tell - the + has screws holding the extruder body together while the original has snap tabs. The problem is not files or profiles but is part of the process of measuring the starting position. There should be a tab of aluminum on the left rear part of the platform; also be sure the build platform is completely snapped in place. If this was a used Mini it might have some filament stuck in the extruder - they rely on retraction of the nozzle to measure the bed.,
Also, check the MakerBot support site as they have recently expanded the self diagnosis area. And the reason I asked about which extruder is that the earlier one is far more prone to jamming. Try this: remove the cold extruder and press the tabs on the side together - this releases the filament drive wheel - then gently press on the nozzle. If the nozzle/heater assembly doesn’t move with light pressure then something is jammed/stuck. Reply back what you find and we can go from there.
I know some versions of Makerbots has trouble with loose wiring. I’d check to be sure all your connections, even into the motheboard, are tight.
7 months later
Having the same issue, the head trys homing off the build platform, any fix???
