Jun 2017
Hi again everyone. Thank you so much for all your answers!!
I managed to sort it out yesterday and i tought i would share my experience here if someone else is doing the same mistakes.
As i said i was using a voltage divider circut using 2 resistors in the 1.5x range from eachother. But i took some spares that i had at home that gave me a total impendence of nearly 2MegaOhms… From what i understand (and i know very little about electronics in this aspect, so please correct me if i’m wrong) that was to much for the 5v signal coming form the mainboard to go through to get ground.
My solution was removing the voltage divider and instead using a diod. the diod was reversed so that the 12volts from my sensor was blocked by the diode, not frying my mainboard. but when the 12v vanished (sensor was close to metal) the 5 volts from mainboard was able to pass right through the diode and reach ground.
Everything is working as intended now (except needing a bit more calibration to get a good height for the nozzle!)
Thanks again!
