The fire risk created by printing unattended is not worth it.
Thanks for the link! I have a somewhat different approach in mind.
It is a legitimate concern. However, I have not seen any fire hazards reported because of unattended printing. If anyone has a bad experience, I would like to know.
Nonetheless, The robotic arm will allow you to monitor the 3D printer remotely through a web-connected camera. As an additional security measure temperature sensor can also be added.In case of fire, concerned authorities can be immediately notified.
There have been lots of fires, this guy lost his whole house and a pet Beware your 3D printer (They can cause fires) (Page 1) — Solidoodle Discussion — SoliForum - 3D Printing Community
When I started out I printed unattended all the time, as I met more professional people I found that they were all shocked I even considered printing unattended.
There is a considerable fire risk, especially with kit printers using screw blocks to connect heated beds, don’t take the chance.
Homemade smoke detection systems are not safe either, the sensor connected to the raspberry pi is burned up before it detects a fire and sends any signal, and your house is gone.
I know it takes some of the magic away to not be able to go to sleep or leave and return 8 hours later to a huge new object, but at least you still have a house. Even if it only burns up your printer the cost to clean up a small amount of burned plastic smoke damage would easily wipe out an entire year of printing work for me.
3DVS
June 7, 2016, 5:56am
14
Yep, just thought it Washington Aldo interesting.
I’ll keep an eye on this talk!
Mirth
June 7, 2016, 2:18pm
15
I print on PVA and honestly, I’ve had to take pliers to one or two prints to get them off. Whatever you make has to ensure it doesn’t damage the bed. This is extra important if its got sprung manual levelling.
Thanks for the input Acrimonius. I will keep it in mind. I just want to add that I have Ultimaker 2+ which has heated bed. So far every single print came off the bed almost effortlessly without any damage to the print.
Mirth
June 7, 2016, 5:27pm
17
You’re most welcome! I was printing PLA with an E3D V6 at 70 degrees on PVA. That stuck way too well!
Mirth
June 7, 2016, 5:30pm
18
Oh, and by the way, I’m a Product Design Engineering student and have previously done (and continue to do) NDA commission work (mainly CAD) for a member of a Fortune 500 company. If I can help in any way let me know!
Thanks! I will let you know.
Mirth
June 7, 2016, 5:45pm
20
Glad to hear it! Here’s my Thingiverse so you don’t lose contact: Thingiverse - Digital Designs for Physical Objects
Glad to help
@DigiPhy3D
Sounds like a noble pursuit!
Perhaps the way cost could be kept lower is by reverse engineering what the intended outcome would be.
If the desired end goal is a way to safely, remotely and automatically clear the build plate perhaps a type of conveyor belt type contraption might work. You could have a type of scraper with a very thin point (think sizing gauges) that removes the print from the surface and it is then pulled forward by ‘arms’ onto the conveyor belt and shipped into a container or waiting bay.
It’s maybe a little outside the field of a robotic arm but there’s a potential it could work to the same effect which could remove a lot of restrictions to the price point obviously encountered when trying to engineer and program a robotic arm which would have many different variables.
Not sure if this helps!
Mason
Beautiful3dPrinters.com
Thanks for your input, Mason! Any input helps! More ideas the better
I always try to apply the K.I.S.S. principle to just about everything in life. At least the best that I can. I think its a cool idea but from my perspective is if all your trying to do is eliminate a 30 minute commute to the office I would be loading those two Desktop printers into my car and bringing them home. Making my home my office and eliminate the overhead of an office and with the increased revenue by a couple more cheap desktop printers. Just seems like more of a hassle than it would be worth.
Evan_3
June 8, 2016, 8:39pm
24
I would like to respond to this, I build an enclosure around my 3D printer with a door and there is insulation on the inside of the box. In the box i mounted an automatic fire extinguisher (Automatic Fire Extinguishers for Boat Engines & Server Rooms ). I leaf my printer printing all the time, did jobs close to 48 hours and u can’t stay home that long. It is a very cheap solution for if the printer really gets on fire. The only disadvantage is that the powder will ruin the printer and probably damage some stuff close the printer, but i don’t expect my printer to get on fire. It’s just a safety measure i never hope to use, but if i need it, i only need a new printer and enclosure and not a new house (and other emotional stuff).
I bought the automatic fire extinguisher at a grow shop in Holland were they sell stuff to build your own weed house (u can imagine the fire hazard of having this in your house )
U can also buy a automatic fire extinguisher they use in server rooms and campers (but they are over 300 euro’s). They contain foam or co2 and they wont severely damage the printer and especially the surroundings if it is in a room with furniture, carpeting or other stuff u surely don’t want to replace after the fire extinguisher went off.
Mirth
June 8, 2016, 8:43pm
25
As an off-topic, why not use a CO₂ extinguisher? There shouldn’t be any reason not to and with a fused system it should work well.
I agree that ABC powder is overall the best but yeah, it can be a huge pain to clean up.
Evan_3
June 8, 2016, 8:53pm
26
As i mentioned they are quite expensive, especially the ones with automatic fire extinguisher function. Because i’m pretty convinced my printer wont start a fire i choose the cheap option. Also the fire extinguisher would have cost the same as the printer. (link: http://www.fireandsafetycentre.co.uk/Products/1280/Strike\_FX\_1kg\_FM200\_Automatic\_Fire\_Extinguisher.html )
I feel your pain. For construction lasercutting is definentely the way to go. Unfortunately I have no experience on the software side of this but i do know with a rasperry pi you can controll gpio in conjunction with something like octoprint. However I do have a ton of experience in manufacturing as well as the mechanical aspects. Good Luck on your project. -Alexander
Mirth
June 8, 2016, 8:54pm
28
Fair enough! Though I wonder, given the enclosed space and small volume could you potentially “make” an extinguisher with a CO₂ canister for IDK, airsoft etc?
Might not be a point even considering it but I’m curious.
