I ran my first print today, or at least started it. But quickly saw that I have an issue with the tension on the drive belts. I have them fairly slack and as a result the head and bed move, in one direction OK, but in the reverse direction they judder. After about 90 mins it seemed they had jumped on the pulleys as it was laying plastic in the same shape but shifted sideways!!!
But how tight should the belts be? Originally I had them tighter and it seemed to make the head and bed stiff to move. Any ideas please?
Also after about half an hour the paper tape on the bed started lifting up!!!
I first thought this was a temporary cover, as it has been put on with wrinkles and bubbles in it!
Then when I realised that this was the base the plastic was to go on I tried to smooth it out, but obviously without much success. I assume it was the bed heating made the tape lift up.
So what should I use there instead of what they supplied?
I found the bed stiff to move when I assembled it and first installed it’s belt. So I then slackened it off.
Clearly as the head drive belt jumped it was too slack, but I appreciate your guidance on how tight it should be.
I notice there is some noticeable stepping even in the other directions, but I guess as they are stepper motors there is bound to be some. In the build when both x and y were not jerking it did lay a pretty straight line.
I will look on Amazon for ‘build plates’ and see what I can find.
Other than the two problems the build was looking pretty good.
I’ve now sorted (I think) the belt tension problem and the X and Y move smoothly.
Tho’ I am puzzled when initializing in the X axis, the nozzle carrier hammers the end stop repeatedly for about 3-4 seconds!
I would have thought the micro-switch would detect the first contact and stop the repeated movement.
I have used the BuildTak 3D Printing Build Surface, but the small test piece I have tried is now stuck so firmly I don’t think it will come off!! I read (on BuildTak) that it is due to the nozzle distance too small. But how can that effect the adhesion?
I removed the original tape from the beginning. U can use hair spray, paper glue stick, ABS ‘juice’ (dissolved in acetone), or special adhesion spray “DIMAFIX”
Thanks, but I do think the switch is physically operating as it contacts the end stop and I do hear the switch ‘click’ when I press it. So I think either it is faulty or the wiring is not correct.
