Nov 2016
Good morning all, im new to 3D printing and have purchased a Prusa i3 Pro b remake.
Im using Cura 15.04.6 and Merlin firmware. Ive spent all weekend reading forums, changing settings and checking printer but can not get a good print. Can anyone help please?
I would upload my Cura Profile file but 3DHUBS will not let me so here it is in text form…
[profile]
layer_height = 0.06
wall_thickness = 0.4
retraction_enable = True
solid_layer_thickness = 0.6
fill_density = 20
print_speed = 40
print_temperature = 205
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 45
support = None
platform_adhesion = Brim
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
nozzle_size = 0.4
retraction_speed = 10
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = All
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 80
bottom_layer_speed = 20
infill_speed = 40
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
perimeter_before_infill = False
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 10
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing…
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing…
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 3rd extruder
G1 F{travel_speed}
M117 Printing…
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
G1 F{travel_speed}
M117 Printing…
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
20140205_marvin_keychain.gcode (2.24 MB)
20140205_marvin_keychain.stl (658 KB)
One thing I noticed is that you are printing at a layer height of 60 micron (.06mm). If you are just starting/tuning, you should be dialing it in at around .200 mm, with calibration cubes and other calibrating prints. Looks to be to hot, either material temp is too high, or not enough cooling.
thanks, i will amend the layer height and try a calibration cube. P.S Im using PLA am i right in thinking the temp should be around 210 'c
Yes 210C isn’t too bad, it will vary from brand to brand. Do some tests, you normally want to use the lowest temp that gives you the best quality. The less heat you have in the extruded plastic the less heat you have to remove with cooling fans.
I would say slow down, more cooling. Maybe print 3 or 4 at the same time and see how they go. It’s not a complete mess so don’t get discouraged!
Thanks. The first print i did was a lot better, its when i started using Cura 15.04.6 it all went wrong…
I was using a basic version of Cura the first time but i updated it…
So to slow the print down i take it i should change “print_speed = 40”
Would you say my retraction settings are ok? are cant seem to work them out!!!
Thanks again
I can’t speak to Cura since I don’t use it.
Yes on speed, I printed Marvin at about 1000mm/min I think it was.
I think what I mainly see in the model is to much heat. Slowing down the layer speed and giving it time to cool between layers I think will help.
Marvin is hard! Too slow and the nozzle will add heat to the layers, to fast and the layer doesn’t have time to cool enough. This is why some suggest print more than one at a time to give a pause to each one to let it cool a bit before the next layer.
Search this site also for Marvin help, there is a lot.
