Sep 2018
Can any one list all the possibilities what can cause the “sequencer timeout 3013:20” error?
which are the most common ones?
Please help me with it.
Continuing the discussion from Projet 660 pro Error:
Hi
What was the printer doing before this error occurred, has the printer been in a constant printing operation or has it been standing for a while?
The error has to do with the connection between the printer and the print heads!
please upload a photo of the heads pogo’s and of the flex cable between the heads and printer
The problem appears sometimes while printing and always when printheads are purged.
The pogo flex cable is brand new. The pogo pins are clean and the springs work properly.
The timing belts are also new. When I replaced the flex cable a was able to purge the heads once.
Now it makes only few strokes and then stops.
In my experience it is a pogo pin issue. Pogo pins are clean and flex cable is new… possibly the pogo card itself might be the problem then.
I have had everything happen to mine and finally it is working. Still I decided to sell it. I am quitting 3d Printing. Good luck!
10 days later
20 days later
I replaced the festoon cable and the printer is ok now
It prints properly and the purging cycle is also working properly
