Mar 2016
it looks like the nozzle is to close to the bed, when the nozzle is to close it can block any plastic from coming out.
try and level the bed with the extruder on the spot where it faild, the bed might not be completly flat but very slightly bowl shaped depening on your suport points.
Definitely contact the printer manufacturer. Hopefully it’s still under warranty. You may be able to get a replacement build plate.
In the meantime, what slicer are you using? You might be able to compensate, if the bedplate isn’t too warped.
If it’s just out of warranty and you bought it with a cc most will double the warranty too.
Big thanks for support to all! It’s works great now!
