May 2015
I downloaded cura and think you get a lot more control with repetier. I did not give it a fair chance though. Im getting some good results with my 0.3 mm head. I adjusted the layer height to 2.4 mm and that seemed to do the trick. The undercuts and curved bridging is still an issue but not as noticeable as before.
Cura is a bit more user friendly than Repetier. It provides a good belance between easy printing and configurability. Good to hear the PrintrBot produces acceptable results again.
Check the PrintrBot talk forum if you run into some issues in the future. It contains lots of expert users, information related to troubleshooting your PrintrBot and expert tips to finetune to print on 100 micron or less :slight_smile:
Ken
Type M501 into Repetier-Host and check what it returns for M92. Your steps/mm should be 80.00 for X and Y, 2020.00 for Z, and 96.00 for E on the Printrbot Simple Metal. This will ensure that your dimensions and extrusion rates are accurate, assuming you’ve entered an accurate filament diameter in your slicer (1.75 or close to it, if you measured your filament with calipers). Are you using the stock 0.4mm nozzle? It should work fine for anywhere between 25 micron to 320 micron layer heights.
One thing i cannot reccomend more is to callibrate your z probe and keep it tight. And callibrate it down to a hundreth of a mm. Also try using a raft. And for the extrustion multiplier i wouldnt change it but change the steps per mm val which is shown on thomas sanladerers youtube channel. Also my ubis hot end never skips you may have a clogged nozzle which i have had before thats the only time my printer has skipped steps. it also may be if you are printing too cold i print at 200 c for pla.
have an early 2013 printrbot simple. i use to print cubes to calibrate to the detail the axis, check the tension of the belts, and make a good control of the temperatures of the filament. I passed the test at fist try, and i think is because i tried many filaments before. I use PLA at 210ºC first layers and switch to 205 after. This model requires 100%fan al the time. my max speed is 60mm/s even 50mm/ ti aassure the printinh have enough time to get cold between layers. usinic3r, but the last version. The bad part of your side is motor skipping steps, i think. and the cooling
Good luck
Yeah, from what I understand Repetier has a lot more fine-tuning options. I’m planning on trying it at some point, but for now Cura is working for what I need it to do. I’m glad you got this working, your print is looking good.
Try running at a higher temperature at a lower speed of under 30. Tighten the extruder and try it again
I would use a layer height of .2064 and a base layer height of .254 this is the reccomended layer height using the 3/8 lead screw according to the prusa calculator and printrbot. Also try slowing down your print i had luck printing marvin at 30 mm/s and also adjust your z offset to the hundreth of a mm and use a raft when printing small intricate objects.
1 year later
fiveangle, thanks for the details here. Have you ever printed Marvin with ABS at 0.1mm?
What settings would you use for ABS?
I assume that your “cooling cylinder” is a second model which you are printing to move the hot end away from the primary print to allow each layer to cool. What retraction settings do you use when doing this?
I have attempted to print Marvin with Yellow PLA and Black ABS on my Printrbot Simple 1403
The PLA print came out nice, but I am still having trouble with ABS.
I have images posted on my hub page:
https://www.3dhubs.com/montgomery/hubs/craig
Thanks
