May 2015
I’ve run into an issue printing this model, where very long gaps appear between the print layers, but not in the first layers of the model. I’ve never seen this before and I don’t really know what caused it.
It’s the first time I use this type of filament and print this model. But I’ve printed very similar models before without any issues so my best guess is that the filament is causing it.
Hopefully someone has had the same experience before and can tell me what happened.
    May '15
    Jan '16
  • 18
  • 1.6k
  • 9
Hey,
Would you specify:
  • What kind of printer you have?
  • What material you use?
  • And what setting did you print this in?
That might help people assist you with it :slight_smile:
Cheers
Yes that might help :slight_smile:
I’m using a flashed XYZ printer 1.0a with Repetier host and Slic3r. It’s ABS, 0,4mm layer thickness, no support. I did one with 60% infill (accidentally) and one with 30%, both had the same issue.
If any more settings are of interest please let me know.
Have you ever printed with ABS before? And, do you have the same problems with for example PLA?
It could be under-extrusion. You may want to have a look at the following link: A visual Ultimaker troubleshooting guide - 3DVerkstan Knowledge Base 3
Click on the under extrusion part to get a description of the main causes of such problems
It is quoted as an Ultimaker troubleshoot manual but you will find that most of the problems appear universally.
Other than that it could be the software that is actually not slicing properly the model. You may have to readjust the settings for contouring (creating the outer layer) the object. Not sure about the default XYZ software but in Cure i’ve had it corrected and solved a similar problem
Hey @Arnoldas, I only print with ABS, so I learned about this early on. On a thin print like this, if you have auto cool on (which he did), some layers may not adhere. This causes the cracking. Hope this helps,
3DPrintedArt
I was able to fix it, but I changed multiple settings so I’m not sure if it was just one setting that did it.
Turned off fan
Increased nozzle temperature (from 230 to 245, filament range was 220-260)
Fixed filament feeding to be a bit smoother (doubt this had anything to do with it, but I changed it recently)
Switched settings to print infill before perimeters.
I think the last one had the most effect, but it might just as well be a combination.
My prints come out great now (see attachment), so I’m really happy with the changes I made.
Front one is with aligned seam, back one is with random seam.
8 months later
This could be a model issue. I always run models through an online fixing tool before printing. I’ve had similar issues and only noticed after studying the sliced item and seeing that the problems in the actual print were also in the sliced model.
