Hi HubMareike,
Thanks for your message. I’d suggest removing the support: a Marvin can be printed without support, especially with a good machine as a Ultimaker.
Which material are you using? What is the temperature?
Best,
Federico
Hi Federico,
thanks for your message. I am using pla. The temperature is “automatic” so unknown as I am using cura 2.1.2. I cannot change anything as is is listed in an inactive greytone. I couldn’t find a way to change that yet.
cheers
Mareike
Hi Mareike,
Thanks for your feedback: I didn’t know that there was a new version of Cura! I downloaded it and I didn’t figure out how you can edit the temperature yet. In any case, considering that you’re using an Ultimaker, you should be able to check and change it on the printer, during the printing process. You can try to set a temperature a bit lower (around 200 C) but I’m quite sure that you can have a great improvement simply removing the supports.
Hi Federico,
thanks so far!
cheers Mareike
HI HubMareike,
Sorry for the late answer, you’re right: the result is clearly better! I’d suggest setting the infill at 10%-20%, it’s enough for a Marvin and you can save filament.
To improve more the quality, you can check the platform’s calibration and eventually try to slow down a bit more the print and the travel speed. In any case, this one is already quite a good Marvin!
Federico
