Here is a cube I am doing trying to dial in some Hatchbox ABS - not the same one as my other post. The pics are of the same spot on the cube from different angles of the lower portion of the corner.
ABS - 210
Bed 90
2 shells, 3 top/bottom 25% infill
QIDI Tech-1 fully enclosed
S3D
The focus is on the deformed lower 1/4 of the corner of the cube.
This is the corner set for start points. I have been turning down the temp to see if this will go away or reduce but it is not.
I am running a print with start point optimized to see how that does.
Let the first layer print, pause, spray with hair spray on the corners, resume and see if it still warps. If it’s not fixed you need to add like small circles to the corners so they have good grip on the bed and later cut them off. Spray should work.
Thanks but I am not worried about the “corner” to bed warp at the moment but the deformed area on the corner going up about 1/4 of the print. It is only on one corner.
