Mar 2017
I am by no means an expert, but here is a link to simplify3d’s support which will show you common errors and ways to fix them.
https://www.simplify3d.com/support/print-quality-troubleshooting/ 3
It looks like your biggest issue is a layer shift, which they talk about on the troubleshooting guide.
https://www.simplify3d.com/support/print-quality-troubleshooting/#layer-shifting-or-misalignment
Other than that, I do not know much about the XYZprinting software because the first thing I did was purchase simplify3d because it gives you much more control over the printer. I believe they made it possible to import gcode from third part software like slicer. You may want to look into getting the free slicer software or purchasing simplifiy3d.
I know that this isn’t the exact answer you wanted but it is all I can do for you. Good luck.
Ian
