Signswise 5PCS Barrel M6 X 30 Teflon Nozzle Throat for MK8 Tube Makerbot 3D Printer Extruder Hot End
Signswise
Link: http://a.co/enZ7Qzj
BIQU 3D-M6 0.4mm Brass Extruder Nozzle Print Head for 1.75mm Filament 3D Printer (Pack of 5pcs)
BIQU
Link: http://a.co/6uhaTEq
At some point the plastic arm or the base of the extruder will crack. You can print replacements or buy this all-metal replacement.
Anycubic All Metal Right Hand MK8 Extruder Aluminum Frame Block DIY Kit for Reprap i3 3D Printer
Anycubic
Link: Amazon.com
If you plan to use a Raspberry Pi running Octopi to control the printer, buy this cable. I spent several months chasing down problems until I did.
Rampow Micro USB Cable - 6.5ft
Link: Amazon.com
The next two items are a good way to team up with your friend as they come in bags of a hundred! These are the little square nuts and grub screws that hold the heat break in place. My biggest fear when working on the hot end was losing one of those guys.
100pcs 304 Stainless Steel Square Nuts M3
by DD-life
Link: Amazon.com
and
M3x5mm 12.9 Alloy Steel Hex Socket Set Cap Point Grub Screws 100pcs
by uxcell
Link: http://a.co/88xEdvI
This is a great fan, but twice as much as others. It’s super quiet (I finally got one.)
Noctua A-Series Cooling Fan Blades with AAO Frame, SSO2 Bearing (NF-A4x10 FLX)
by noctua
Link: http://a.co/jg307qT
These are much noisier, but work fine. You can also find fans like this on eBay for
half what Amazon charges. Look for 12v 40mm x 10mm fans. (I keep a couple as
spares.)
2packs 40mm x 40mm x 10mm 4010 12V 0.15A Brushless DC Cooling Fan 2pin AB4010M12 UL TUV
by Security-01
Link: Amazon.com
This is the tape that holds the insulating batting onto the hot end. I bought some replacement batting on eBay, but have yet to use it.
BCP Kapton Polyimide High Temp Tape with Silicone Adhesive 1/2" (12mm) x 36yds
by BCP
Link: http://a.co/dh0SRPx
Finally, there are people on the FB group who are wizards at this.
