Hello!
I’m currently working on my Anycubic Delta Printer (Linear Version) and there seems to be something wrong when I enter the auto home setting into Fronterface.
Both the Y and Z seem to be going up fine and stop when they reach the top but the X goes up, and when it reaches the top and should stop, it keeps trying to go up which results in loud noises.
I can only describe the sound as when you are using an electric screwdriver and the screw can’t be screwed in anymore so it makes a fast, loud thudding noise.
How can this be fixed?!
Please help!!
DDDruk
Try checking whether your end stop switch is working properly. You can check it with a simple multimeter. Just connect the two leads of the multimeter to the two wires of the stop switch and see the whether the multimeter chimes. It might be also that you got your + and - cables are the other way than in the code. Just rotate the end stop switch cable connector by 180 degrees and see if that helps. Hope you get it sorted out.
DDDruk
Try checking whether your end stop switch is working properly. You can check it with a simple multimeter. Just connect the two leads of the multimeter to the two wires of the stop switch and see the whether the multimeter chimes. It might be also that you got your + and - cables are the other way than in the code. Just rotate the end stop switch cable connector by 180 degrees and see if that helps. Hope you get it sorted out. Those printers are horrible.
