Mar 2016
I did 3 things that eliminated my filament jams.
Added an oiler to the filament. Mine was made from a small felt pad placed in a small plastic cup with holes for the filament.
The cup keeps the pad out of the extruder. A few drops of olive oil is applied to the pad every week or so.
Switched to all metal hot end to eliminate the ptfe tube.
Replaced the crappy bushing fan that came with the all metal hot end with a good ball bearing fan and
associated duct to cool the cold part of the all metal hotend.
I run the PLA about 230c. If I run much cooler I get poor inter layer bonding at my print speed and layer height.
Hi there,
I am printing on a Makerbot 5th gen, with the smart extruder. That started to happen to me a bit after many hours and many prints. I took a closer look at the nozel and it looked pretty beat up. I think the higher pressure of “loading” more material through the nozzel was fine, but then the lower pressures of the material during an actual print may cause a bit of back up over time. I might suggest a bit of an increase in temp during your prints, and also maybe look into replacing the nozzle. When I replaced mine, it cleared up a lot of issues.
I hope that helps!
3 years later
I think the major trouble you are facing is due to an inefficient printing filament. Get a better quality 3D printing filament from a credible source such as ‘3D Printers Bay’ and you can expect better results.
