I had some Z-arteifacts on my Ultimaker so I decided to clean my Z-screw. You know, strip the grease and reapply. This process requires unplugging the Z-motor and removing it along with the screw. I did that, cleaned the screw and put it back in.
When I switched it on, I think I saw a small spark under the printer, I am not too sure anymore. Anyways what I was sure of, was that the printer did not turn on. I waited at least 10 seconds before walking to my laptop to scout the forums. While waiting for the page to load I looked over and my UM was turned on!
I then switched it off and on a few more times and it turned on instantly. I’ve never built my own printer before but is this a standard start up behaviour? Like first configuration or the controller is intelligently testing the voltage individually?
Okay not sure if it’s the power cable itself or the socket or the controller. Shift it and the power went off and on again. The “spark” I saw was the yellow LED light on the board and it makes this spark sound when the connection is halfway in contact.
Are you sure you have that locking connector plugged in all the way? I’ve seen that sort of behavior when someone has ‘helped’ me put all my printers back in place after an event and hasn’t locked that connector in all the way.
Then you probably need new Z bearings and/or rods. Contact your reseller about this.
I would fix this power issue also. It probably got pulled hard enough to damage the cable or the board. I would probably confirm it’s not the board and then gently rip open the end of the cable (a lot of work) and re attach all the wires. Or even better - try to buy the same connector and then cut off the bad connector and solder the 4 wires to the new connector.
