May 2016
When you load filaments is it coming through?
If yes, What slicer are you using? I started straight with simplify 3d, my errors that caused this was:
1) wrong material selected (temperature was 50C too low)
2) I had the fan on max for abs starting at level 1; which cause it to cool too quickly and it would clog the extruder.
Did you swap those?
You need to use 205 for PLA and 230 for ABS.
Did you load your filament through the firmware? Does the filament flow freely while loading?
Is your filament diameter greater than 1.75mm? If it’s not feeding through at all your filament may just have a buldge in it.
I have somewhat the same issue. The print start perfectly then after a while (random) the print behaves like everything is OK but no filament is coming out. This happens with ABS and PLA using simplify 3D or flashprint… Loading the filament works perfect and the filament freely come out… I suspect the spool being too hard to spin… So at a certain point the extruder cannot get filament anymore. I am trying now with a new spool holder… I also suspected my printer not to be week leveled (not the bed, the printer itself). So I changed where the printer is lying… Note: this happens only on my left extruder…
Sure. Take the fan and cooling sink off. Remove the stepper if you want or you can just leave it on the cooling bar. Look at the feed guide and the roller. Make sure they are lining up. Let me know if that was the problem. If not you might need to remove the extruder head and check the teflon tube if you have not done that.
