May 2016
When you load filaments is it coming through?
If yes, What slicer are you using? I started straight with simplify 3d, my errors that caused this was:
1) wrong material selected (temperature was 50C too low)
2) I had the fan on max for abs starting at level 1; which cause it to cool too quickly and it would clog the extruder.
Did you swap those?
You need to use 205 for PLA and 230 for ABS.
Did you load your filament through the firmware? Does the filament flow freely while loading?
You can push it manually through before it stops going through? Or are you saying that when you push the filament through manually it is fine but when the printer tries to feed it through it will stop?
If it is the first I would imagine there is still a clog. If it is the second then I think the spring to the extruder is miss-aligned or the bolt needs to be tightened a bit more. Could also be the drive gear is getting worn and needs to be replaced.
Have you checked out the troubleshooting section onthis page: Flashforge Professional 3D Printer Manufacture - 浙江闪铸三维科技有限公司 26.
Also just a side thought, have you tried printing with a different filament? Bad filament could be the culprit too.
Not sure what you are trying to show me here but that black rectangular cube you printed does not look very good if you are trying to prove to me 205 is an excellent temperature to print ABS. You are most definitely having bridging issues. You should probably use a cooling fan for bridging if you are not. How could it possible hurt to use a higher temperature? But whatever works for you. PLA melts at a much lower temperature than ABS so it would make more sense if you use 205 for PLA and 220-240 for ABS.
Sure. Take the fan and cooling sink off. Remove the stepper if you want or you can just leave it on the cooling bar. Look at the feed guide and the roller. Make sure they are lining up. Let me know if that was the problem. If not you might need to remove the extruder head and check the teflon tube if you have not done that.
